Laars Endurance EBP Heat Exchanger
vanzes
vanzes Member Posts: 2
I picked up a 2nd hand Endurance EBP and have done a few replacements - new ignitor, pump cartridge kit etc. Now I'm needing to replace the heat exchanger but they look to be pretty dear.
Any suggestions for non-OEM substitutes?
  • kcopp
    kcopp Member Posts: 4,623
    Just replace the whole boiler. There is no sense in replacing a HX on that unit. You will not find a non Laars hx replacement.
  • Zman
    Zman Member Posts: 7,611
    A second-hand Endurance is a lot like a second-hand hot tub. It wasn't built very well to begin with and you have just inherited someone elses problems.
    Albert Einstein
    kcoppjad3675
  • psb75
    psb75 Member Posts: 1,100
    If you replace the boiler...don't replace it with another Endurance.
  • vanzes
    Oh I can feel the love here.
    Should I start a new thread for budget friendly similar options? It's for a very small space, the difficult part to find it seems is the domestic water.
  • Zman
    Does a wall-hung condensing combi fit the space. There are lot's of good ones out there, this might be a good fit. https://www.lochinvar.com/products/residential-boilers/noble-fire-tube-combi-boiler/
    Albert Einstein
