Laars Endurance EBP Heat Exchanger
vanzes
Member Posts: 2
I picked up a 2nd hand Endurance EBP and have done a few replacements - new ignitor, pump cartridge kit etc. Now I'm needing to replace the heat exchanger but they look to be pretty dear.
Any suggestions for non-OEM substitutes?
Just replace the whole boiler. There is no sense in replacing a HX on that unit. You will not find a non Laars hx replacement.0
If you replace the boiler...don't replace it with another Endurance.0
Oh I can feel the love here.
Should I start a new thread for budget friendly similar options? It's for a very small space, the difficult part to find it seems is the domestic water.0 -
Does a wall-hung condensing combi fit the space. There are lot's of good ones out there, this might be a good fit. https://www.lochinvar.com/products/residential-boilers/noble-fire-tube-combi-boiler/"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
