Steam Boiler UnInterrupted Power Source
Peter Rozano
Member Posts: 17
I have a rental unit and, due to a change in circumstance, now live about 65 miles away. The building has a gas fired steam boiler (so I don't have to worry about pumping oil). The Texas power blackout in 2021 has got me thinking. How big of a UPS would I need to run a gas fired steam boiler in the event of a freezing winter blackout? My true goal is to prevent pipe freezing.
Is it atmospheric, or does it have a blower?
If it's atmospheric you could run quite a while on a UPS. If it's a blower, not very long at all.
You can hook up a kill-a-watt or other meter to your boiler to see how much it draws and do the math. There are several threads from the last few years here you might search for also.
But 65 miles isn't very far. You might consider an internet temperature device so you can monitor the temp or get notified if it drops. You'll have many many hours or days before the pipes freeze. Will they even freeze in Texas?NJ Steam Homeowner.
Thank you all for your advice. The meter may be the way to go to get started. For the record, there is no blower. My electric draw should be the pressuretrol, automatic water feed and the automatic vent dampner, none of which seem like heavy draw items to me. Perhaps I am wrong...0
Plus the gas valve don't forget
But yeah it won't be much of a draw, but most UPS's don't run very long.
Is this property vacant? Won't the tenants call you when they don't have heat?NJ Steam Homeowner.
You can disable the vent damper (at least that's what one of my friends told me🤫🤫).0
if its atmospheric you could put a standing pilot millvolt valve and it runs with no house electricity. now i see your second post with more info on the system. you'd need a float style low water cut off. You could still run an electric auto feeder separately which wouldn't fill during outages and I'm pretty sure that some dampers spring open on power failure.
- 117 Geothermal
