Steam from chimney
Don_175
Member Posts: 174
Have a 6 year old boiler. It has added about 3 gallons of water since the season started. With this super cold weather we are having in Ohio, it has been adding about a gallon per month. I just happened to be outside recently and saw some steam around chimney. Not a huge amount but it is visible. But it’s also been about 20 degrees. Is that normal? How much should one expect to see as far as water usage if a boiler has a leak above water line? Thanks
Some condensation and visible steam is quite normal, particularly in colder, more humid weather. If you are only adding a gallon a month, you don't have a problem.
To answer your question directly, a leak above the water line is likely to result in gallons --that's; plural -- per day.Br. Jamie, osb
Thanks Jamie. That’s what I was thinking but I’d never seen steam coming out of chimney before. Must be because it’s been so cold.0
Gas fired systems will show visible vapor at the chimney or vent in cold weather, due to the very high moisture content in the exhaust gases. This is normal.—
Bburd0 -
