Looking for a battery backup for a Bosch Combi Boiler System. "The Hugo" won't work?
btrem49
Member Posts: 2
Battery backup system for a Bosch Combi furnace.. ?
Battery’s to run the boiler?0
You’d need a UPS with sufficient capacity to power the boiler, pumps and any ancillary controls.Bob Boan
calculate how much power is required to run the boiler and any pumps required, plus the inverter itself. then how long you want to run off if the battery, size the batteries accordinglyBob "hot rod" Rohr
Bosch boilers use 2amps or less. A little more than a modern gaming PC.Sal Brunetto
National Sales Manager
Bosch Thermotechnology0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
