Looking for a battery backup for a Bosch Combi Boiler System. "The Hugo" won't work?
btrem49
btrem49 Member Posts: 2
Battery backup system for a Bosch Combi furnace.. ?
    pecmsg Member Posts: 6,238
    Battery’s to run the boiler?
  • Ironman
    Ironman Member Posts: 7,724
    You’d need a UPS with sufficient capacity to power the boiler, pumps and any ancillary controls.
    Bob Boan
  • WMno57
    WMno57 Member Posts: 1,408
    What is "The Hugo"?
    PC7060mattmia2
    hot_rod Member Posts: 25,235
    calculate how much power is required to run the boiler and any pumps required, plus the inverter itself.  then how long you want to run off if the battery, size the batteries accordingly
  • BoschGuy
    BoschGuy Member Posts: 5
    Bosch boilers use 2amps or less. A little more than a modern gaming PC.
    Sal Brunetto
    National Sales Manager
    Bosch Thermotechnology
