Small nozzle problems
Jon_blaney
Member Posts: 329
in Oil Heating
I see random references to issues when you use an oil burner nozzle sized less the .75 GPH. When you shop for smaller boiler/furnaces, .50, .60, .65 burners are listed. So, are they a problems or is it an urban legend?
eh? What kind of problems. Use the correct nozzle for the firing rate of the appliance, and filters...Br. Jamie, osb
Maybe you are referring to them clogging more easily? Appropriate filtration is important.0
the smaller the nozzle the more likely they will plug. Double up on filters and or a spin on filter. Some use a "sludge pot"0
I'm firing a .60 at 175 psi with a Riello F5 in my POS WM WTGO-3 and Tiger Loop Ultra.
I just recently did my service after about 3 years because the vacuum gauge hit 10".
Been that way for 20 years. No issues.
