burning embers coming out of heat pump???
piglet
Member Posts: 2
I have used a heat pump in my woodshop for years. It has been super - till this morning. I built a box surrounding the air intake to hold about 15 extra square feet of filters, which I try to keep unclogged - but a lot gets past them. I noticed embers this morning where the air exits the unit., so I shut the whole thing down and cleaned the inside coil really well and the squirrel cage fan too (both were pretty clogged up. Then the air started flowing like it was new when I was running just the fan. When I turned the heat back on - burning embers again! What should I be checking? What are the possibilities?
Does your heat pump have any resistance booster strips? If you are getting embers, something in there is getting hot enough to at least make them glow -- and the ordinary heat pump coils are nowhere near that. Another possibility is a bad bearing on a fan.Br. Jamie, osb
yeah,
check your homeowners insurance,
# no embersknown to beat dead horses0 -
Thank you, Jamie Hall. Squirrel cage was clogged to the point that little air was passing, debri on heat strips. cleaned all, now all is fine!0
