Weil McLain Ultra 230 heat exchanger condensate corrosion and leak
tigerdrvr
Member Posts: 2
in Gas Heating
Found water puddling under the boiler and upon inspection found a corroded hole next to the condensate drain. Boiler was installed in 2006 and is running 12 zone system and heat exchanger for domestic hot water. System is using glycol and I don't have any reason to believe there has been introduction of corrosive elements. There is a trap in the condensate drain piping. Not sure if the drain area is installed with a stainless steel cup.
Any idea if WM is standing behind these expensive units? If not is it even worth trying to repair or am I looking at a replacement?
Off the top of my heat it was a 10 year heat exchanger warranty. To swap that out is still much less than half the cost of new. But you end up with other parts that are a bit older. I really like how dependable that boiler was, but the aluminum not liking the acidic condensate sorta made it a deal breaker.
I would listen to Kcopp, nurse it through this winter with a repair if you can do it safely, and spend the summer negotiating!
Tom
Montpelier Vt1 -
If you have the CP#, you might be able to get a warranty if the client is the original owner.tigerdrvr said:Found water puddling under the boiler and upon inspection found a corroded hole next to the condensate drain. Boiler was installed in 2006 and is running 12 zone system and heat exchanger for domestic hot water. System is using glycol and I don't have any reason to believe there has been introduction of corrosive elements. There is a trap in the condensate drain piping. Not sure if the drain area is installed with a stainless steel cup.
That was a common issue with the Ultra and revisions have been made to the flue. Instead of stainless, it's now polypropylene, and they incorporated a pipe for the condensate to go directly into the drain rather than pool in the bottom of the HX.
After 16 years though, what else can go wrong that might benefit upgrading to a Series 4.1 -
Any recommendations on a replacement unit when it comes to that?
That boiler was manufactured 7-03-07 and should have 20% left on the warranty. This means that you will get a 20% discount on the replacement heat exchanger. Call 1-800-654-2109.0
