Thermostat help
I have a separate heater in my garage (Reznor) that is controlled by a Honeywell CT87K1007 thermostat. We use the heat on an irregular basis. The power is on, but the furnace is not starting when I turn up the temp on the thermostat. looking for possible solutions.
  • homeownerMary
    homeownerMary Member Posts: 2
    Thanks for the tips. It uses gas and the line is open. I’m not smelling gas, which should mean that there is no pilot. I don’t hear anything when I turn up the thermostat. The power is on and the rest of the outlets in the garage are functional.
  • ratio
    ratio Member Posts: 4,229
    Take a picture of the back of it. Try to get the gas valve in the pic as well.
  • rick in Alaska
    rick in Alaska Member Posts: 1,524
    I would bet with that thermostat that it is just a bad one. As tommay says, try taking the thermosat off its base base and jump the wires and s if it works. If it does, it is a bad thermostat and needs replaced.
    Rick
