GB 142 gurus...
kcopp
Member Posts: 4,630
I have a low/ no heat call to go to in the morning.
Customer says there are getting error codes of OY, 2F and 4F..
Im looking all over... could be air bound or bad sensors.
Any thoughts so i can get a head start of making a repair?
TY, kevin
TY, kevin
https://www.powerequipmentdirect.com/manuals/GB142Service.pdf
See p. 22 for "OY" (also a Jewish term for when you're in trouble) and page 23 for "2F". I don't see anything for 4F.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
Thanks.
makes me think more so that this unit is air bound...
All those codes are dealing with the supply temp being too high: flow problem or bad sensor.Bob Boan
