Adding toggle switches to thermostat circuit
lost11
Member Posts: 40
i was thinking about rewiring my controller (argo arm-6p). figure 1 is what i have currently. I'm thinking of figure 2 or figure 3.
i was trying to to trouble shoot one of the zones. had to take the thermostat apart to jump the contact. and then i put a jumper between the tw/tr to turn the circ on. i was thinking it would be nice to have easy to use controls that i could disable a thermostat without having to remove the wires.bburd said:Why? What problem are you trying to solve?
no real problem to have control at the relay board itself.0 -
Only Slumlords put switches on thermostats.
How many times do you think that will come in handy? It's like living in Death Valley and owning a snow shovel.
Yup. The only time I ever saw this done was at a rental property. The landlord had toggle switches added to the zone control panel so he could disable the thermostats if someone owed rent money.HVACNUT said:Only Slumlords put switches on thermostats.
How many times do you think that will come in handy? It's like living in Death Valley and owning a snow shovel.0
- 117 Geothermal
