Adding toggle switches to thermostat circuit
i was thinking about rewiring my controller (argo arm-6p). figure 1 is what i have currently. I'm thinking of figure 2 or figure 3.
  • bburd
    bburd Member Posts: 1,324
    Why? What problem are you trying to solve?
    Bburd
    mattmia2kcopp
  • lost11
    lost11 Member Posts: 40
    edited January 2022
    i was trying to to trouble shoot one of the zones. had to take the thermostat apart to jump the contact. and then i put a jumper between the tw/tr to turn the circ on. i was thinking it would be nice to have easy to use controls that i could disable a thermostat without having to remove the wires.
    no real problem to have control at the relay board itself.
    mattmia2 Member Posts: 18,026
    I'd just jumper it at the zone controller with an alligator clip test lead for testing
    bburd
  • lost11
    oh, attach the alligator clip to the exposed copper of the cable?
    any suggestions to block out the thermostat trip to the zone?
    HVACNUT Member Posts: 7,664
    edited January 2022
    Only Slumlords put switches on thermostats.
    How many times do you think that will come in handy? It's like living in Death Valley and owning a snow shovel.
  • SuperTech
    SuperTech Member Posts: 2,669
    Yup. The only time I ever saw this done was at a rental property.  The landlord had toggle switches added to the zone control panel so he could disable the thermostats if someone owed rent money.
    lost11
