Dremel grinding disc lost in bolier
Zolof808
Member Posts: 3
Using a Dremel to resurface the flange on a Peerless JOT steam boiler, the disc went flying off and is now lost in the bottom of the boiler.
Never had this happen before, so it didn’t seem necessary to make a cover for the open hole. D’oh!
The disc is a 1.5” aluminum oxide Dremel # EZ541GR.
How bad is this?
I have made some effort to retrieve it, but no joy. Colder weather is coming, and I’d like to button it up.
How bad is this?
Yes, that’s the plan for the future, but trying to get a bit more life from this one.0
Chemically, it probably is no big issue. If the disc moves around and any pipe connections are large enough, like a drain, over time as the disc disintegrates, it might get lodged in one of the lines. Hopefully, it wouldn't get stuck inside the drain valve and keep it from shutting all the way.
Its hard to tell, other than wild speculation how likely that possibility would be.
Does anyone have any experience with something like this?
Thanks, Jamie Hall. I appreciate the confirmation.
Thanks SteamingatMohawk, I was concerned about what it would do as it breaks down - both chemically and from a ph perspective. As for possible clogging of the drain, it has been upgraded with a 3/4” Apollo ball valve. Hopefully it won’t clog easily and will allow the scraps of the wheel out in future.0 -
- 50 Industry Classes
