How did this make it off the assembly line
Le John
Member Posts: 247
How did this ceiling plate make it off the assembly line. I must have 10 or 15 more like it. This manufacturer needs better Quality control procedures!
I've had a few like that. I like it almost as much when they include plates for 1/2' rod in my box for 3/8" rod. Or they forget to thread them0
Made on a Friday
Or maybe it's a new device to allow you to angle the hanger off to one side or the other, using washers?Br. Jamie, osb
I had a bunch of these that were flat.
They actually fit nicely inside of unistrut/power strut etc.
I used them rather than channel nuts.
1/3 the cost and easier to slide in position.
Enough threads for good support.
Just to deliver a positive point for them....if flat.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
