VRV or VRF
What is the difference between VRV & VRF systems?
    hot_rod Member Posts: 27,346
    kcoppGGross
  • ratio
    ratio Member Posts: 4,219
    One's a trademark IIRC, the other not.
    In the vernacular they're interchangeable; when I'm talking to the factory I'll often use the other guys' terms. Try it, it's fun!
  • retiredguy
    retiredguy Member Posts: 1,090
    You will always get the same result when talking about relief valves as in "the relief valve on my steam boiler is set at 15PSIG". Wrong, that should be the safety valve on my steam boiler. Relief valves are for water, safety valves are for steam, as per the insurance and state inspectors in Pennsylvania.
    EdTheHeaterMan Member Posts: 12,062
    But what do they know!
