How did this make it off the assembly line
Le John
Le John Member Posts: 247
How did this ceiling plate make it off the assembly line. I must have 10 or 15 more like it. This manufacturer needs better Quality control procedures!
    EBEBRATT-Ed Member Posts: 18,165
    I am sure it warped on the boat coming over from China
    bucksnortdelcrossv
  • Shane_2
    Shane_2 Member Posts: 199
    I've had a few like that. I like it almost as much when they include plates for 1/2' rod in my box for 3/8" rod. Or they forget to thread them
  • ChrisJ
    ChrisJ Member Posts: 16,821
    edited January 2022
    Made on a Friday
    Jamie Hall Member Posts: 26,148
    Or maybe it's a new device to allow you to angle the hanger off to one side or the other, using washers? >:)
  • JUGHNE
    JUGHNE Member Posts: 11,452
    I had a bunch of these that were flat.
    They actually fit nicely inside of unistrut/power strut etc.
    I used them rather than channel nuts.
    1/3 the cost and easier to slide in position.
    Enough threads for good support.
    Just to deliver a positive point for them....if flat.
