Steam System Nomenclature
stormbytes
Member Posts: 36
Please explain the following terms:
1. Runouts
2. Take-offs
3. Risers
4. Drips
Feel free to add more anatomy if I left any out
Tia!
PS: Already bought / reading Dan’s book.
1. Runouts
2. Take-offs
3. Risers
4. Drips
Tia!
Runout a pipe feeding or returning from a radiator consisting of horizontal and vertical pipe
Take off a run out's or branch pipe connection to supply or return main
Risers a vertical pipe could be supply or return with flow up or down
Drips a pipe dripping (draining) condensate from a steam pipe either from a main, riser or runout
or branch
Steam branchor a pipe with a take off from a steam supply or return main that feeds several takeoffs
return branch
Some might call a branch a sub main0 -
The runout starts at a takeoff.0
The takeoff is where the runout attaches to the main.0
