The Case for Radiator Covers
HeatingHelp
HeatingHelp Administrator Posts: 706
edited January 2022 in THE MAIN WALL
imageThe Case for Radiator Covers
Landlords should cover all the radiators in the apartments that had little ones living there. I’d also make sure the system was working as it’s supposed to work. It’s the right thing to do. It’s common sense. And the stakes are simply too high to do otherwise.
Read the full story here
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,779
    Wow that is scary. So if the landlord covered every radiator, his heating costs would rise. Plus the cost of the covers It seems like common sense has been replaced with lawyers in this country. Perhaps radiators should be painted red with a large sign saying, Hot Thanks for sharing.
    Ray Wohlfarth
    Boiler Lessons
    ReggietheLandlady65delcrossv
  • SlamDunk
    SlamDunk Member Posts: 1,751
    edited January 2022
    I know everyone says covers reduces radiation but I haven't experienced that after I covered every radiator in the house. We are just as comfy and burn roughly the same amount of gas as we did before we installed covers. The cost of covers are expensive but for us it was an aesthetic issue. If I were a landlord, tenants would be made aware of the dangers of hot radiators and would have to sign a waiver when they sign a lease. You can't claim ignorance if you read, understood and acknowledged the warning.
  • cross_skier
    cross_skier Member Posts: 201
    They are pretty ugly and that might be a problem with some homeowners.  A table with an iron base to block toddlers would be good.
    CLamb
  • SlamDunk
    edited January 2022
    Yeah, I like that. but wrought iron is more expensive than sheet metal. And, my rads are beneath windows.
  • cross_skier
    That one was recycled from an antique daybed which was free
    SlamDunkReggietheLandlady65
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,638
    The covers reduce convection more than radiation. It's the solid top that slows the flow of air.
    And there are much more attractive covers available that the one in the pic. That's more typical of what you'll see in the older buildings.
    Since steam radiators are mostly oversized, many people don't miss the reduction in conduction with the covers on.
    Retired and loving it.
    SlamDunk
  • I am a landlord. I got some wood, nails and my staple gun. Measured all of the various radiators in the rental unit. I made a slightly oversized wood frame for each of the radiators. Went to Lowes; bought some of the pretty metal covers for the front (cut them to size); stapled them on the inside of the wood frame. They look great; last forever and don't rust out like the metal ones can
    cross_skierCLamb
  • DanHolohan
    @ReggietheLandlady65, thanks for caring about the kids. You're pretty special.
    Steamhead Member Posts: 17,854
    I like this. Where do you get them?
    Consulting
  • delcrossv
    delcrossv Member Posts: 2,184
    edited January 2022
    We're landlords too. Tenant with 2 year old just made an open cage of slats around the two big rads in their front room. The bedroom rads are arranged so so one can get "stuck" behind them. Their kid already knows not to get too close to the "hots".
    We've generally been removing the covers from the other rads in the building and switching colors from silver to black to increase radiation. Made a big difference in tenant comfort. 👍
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,388
    Install covers with holes on the top. Will actually increase heat output
  • STEAM DOCTOR
    Holes on front and top
  • STEAM DOCTOR
    edited January 2022
    I am sure that if put on covers that reduce heat output, you will be sued every time kid gets sick. Landlord fault that heat output was reduced. For that matter, if kid rolls off bed and gets injured,  landlord will also be sued. It's the landlord's floor after all.
  • cross_skier
    @Steamhead. The table is not mine, but is a source of inspiration from my better half for a front hallway table over a narrow steam radiator.  She says the table was made by a diy couple in Europe featured in a show on Peacock called "Escape to the Chateau".  We have had two or three instances where little ones have touched the hot radiator so this has been a priority.
  • Voyager
    Voyager Member Posts: 403
    I don’t know many 9 month olds who can read a sign.
  • Voyager
    While I agree that landlords have a responsibility here, we should not let the parents off either. The landlord should provide covers, but the parents should have taken turns spending a few nights in jail for placing a bed so close to the radiator that a child could roll off it onto or behind a radiator.
    CLamb
  • JakeCK
    JakeCK Member Posts: 1,496
    I don't want to think about this. I have a one year old. At least I only have hot water, not steam.
    One of my cats did get stuck between the wall and one of the bedroom radiators once. I was lucky I was home and in the room when the cat fell off the rad.
  • delcrossv
    edited January 2022
    These guys are the go to shop in Chicago, I'm sure there're others out East. Ordering with the humidity pan is a good option.
    https://barkermetalcraft.com/
  • SlamDunk
    Got half from Monarch then the other half from Arscometals.com. I think Monarch shut down.
    Not one of these has top grilles.
    Consulting
  • BobKing
    BobKing Member Posts: 1
    I was in Central Radiator Cabinet Company on Elston Ave. in Chicago with my dad about 45 or 50 years ago. My dad knew the man who made the covers a little bit, and we must have bought a couple here and there for jobs.
    My dad opened the top of a cabinet there, and stenciled on the bottom of the top was "Central Radiator...", and my dad said to me, "If you open the cover on a radiator and it doesn't say, 'Central Radiator', kick it!"
    I thought it was funny. He had something corny to say on a regular basis and I got to ride around the city with him doing service and sales calls. It was a huge privilege (that I didn't appreciate like I do now) and a lot of carefree fun.
    Recalling this, I had to google... it looked like maybe Central Radiator Cabinet Co. is gone 'permanently closed'. However, I picked up the phone and dialed the number just now, and after a lot of rings, a message came on saying they are there dealing with cabinets still today/
    Those were nice heavy covers as I recall. I remember a lot of them in churches I've worked at. And to this day when I open a lid on a radiator cover, I look to see if 'Central Radiator' is on the bottom of the lid, and I remember my dad. But I never bother to kick the cover if it isn't Central Radiator's, because he was obviously just being silly.
    delcrossvSlamDunkbucksnort
  • DanHolohan
    Beautiful story, @BobKing. Thanks for sharing.
  • delcrossv
    edited January 2022
    I believe you can order them such, no one does though as they use them as tables etc.
  • mastercraft
    mastercraft Member Posts: 24
    40 years in the biz & I could never understand solid rad covers! Talk about impeding the convection.
    So, growing up with upright rads(was gravity, but I closed the system & made it fhw) my Mom, good love her, used to prop the cover open during the winter months. This resulted in much more comfort......Unfortunately, the ‘insulation’ underside of the cover was corrugated asbestos. She later, at a young age died of lung cancer. Never smoked a day in her life. Couldn’t get the doctors to rule it as mesothelioma but they also wouldn’t rule it out. Embarrassed that I had never noticed the insulation. It was also the only rad in the house that had it (?). A month after she passed, I had my abatement guy ‘glove/bag’ it hopes that it didn’t affect my Dad. Sorry to go on & on but I miss that incredible woman every day!
    Somewhere on this site are at least two articles showing the negative effect of adding covers to existing radiators- up to 1/3 reduction in output- but I can't find them now..................
    Consulting
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,360
    President
    HeatingHelp.com
  • Glenn_16
    Glenn_16 Member Posts: 14
    And you have to love bleeding a system in an old Evanston three story when every single one has enclosures that also serve as bookshelves, display cabinets, desktops,,,,all waiting for your patient removal to get to the vent that's been painted 26 times prior to the covers being installed.
    delcrossvJimbabwe
  • DanHolohan
    @Glenn_16, that cracked me up. Oooof. Thanks!
  • Jimbabwe
    Jimbabwe Member Posts: 10
    Oh how I despise Evanston. Yuck. But Chicago is the same. It always annoys me to no end that we are expected to remove all of ther people’s belongings when called out for service. And the paint, don’t even get me started lol
    delcrossv
  • delcrossv
    Good reason to bill by the hour. 😉👍
  • jumper
    jumper Member Posts: 2,461
    Lots of radiators only have a shelf on top. For steam that is an improvement because radiation is pleasant and because reduced convection keeps radiator warm longer. For low temperature HHW I don't know.
