Tips for removing old 3/4 brass vent?
Jells
Member Posts: 643
Well, I didn't get lucky. Wanted to swap out what appears to be a nonfunctional main vent for a Gorton 2, but the hex didn't hold a large Crescent and even a 24" pipe wrench couldn't get enough traction on it. If this were in an easy to reach spot I'd cut it off and cut out the stub from the inside, but this is a pretty awkward location for that. Ideas?
And yes, I realize that's probably asbestos and I should wear a mask.
I would soak the threads with PB Blaster or Kroil....several times.
Then "3 point" your pipe wrench on the largest part of the vent.
That is having the bare hook of the movable jaw against the back side of the vent.
This helps egg shaping the brass.
If the jaws slip, perhaps a better pipe wrench is in order.
Also a spray bottle of water will keep the insulation from turning to dust.0 -
Hi and yes, you can sharpen pipe wrenches. If the steel in the jaw is soft enough, a small triangular file will work. If not, use a Dremel tool with the right angled grinding stone. Another trick for getting the vent loose is to try tightening a bit first.
Yours, Larry0 -
Could try a chain wrench or maybe vice grips too but you would have to be real careful about not just snapping it off with the vice grips.0
Thanks all. I'm going to try the PB Blaster with a 14" but newer genuine Stillson. More appropriate size for that fitting anyway. I'll have a pipe ready to slip on the handle if I need more leverage. Pulling hard on a wrench while standing on a ladder is always good for a few heart stopping moments!
I'll also try and and sharpen up Grandpa's wrench with a die grinder and stone.0 -
Hi, Maybe you should consider removing enough of the insulation so you can get a second wrench on the pipe. With that, you can just squeeze between the wrenches without any heat-stopping moments!
Yours, Larry0 -
@Jells You have the right idea. A smaller wrench with a cheater will work better you will get more teeth on the vent. Emt conduit for a cheater is lighter and easier to use1
If your going to spray water to control free asbestos put a drop or two of dish washing liquid in the spray bottle and shake it up. That acts as a surfactant and makes the water more slippery so penetrates better.
3PSI gauge0
- 117 Geothermal
