DHW Overrun
edwardjohnson07
Member Posts: 1
Hello, I have a Vitodens 200 WB2 6-24 and my DHW continues to overrun my serpoint of 122 degrees. I’ve seen it as high as 158 degrees and had to manually close the feed valve to the tank. I’ve replaced the LGM29 and VR20 as well as the thermo probe on the DHW tank. Thoughts on why it won’t shut off automatically when it’s at temp? Thank you in advance!
Is the indirect tank a Triangle Tube?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
