Dunkirk 90 Quantum
Johny86
Member Posts: 3
Hello guys i have Dunkirk 90 Quantum. When my zone 2 is trying to turn on its making clicking noise and seems like it can not connect to turn it on.
Please any help is appreciated.
If you copy the link i posted video on Youtube.
Thank You0 -
I assume you have 2 zones? I would try bypassing the thermostat connections in the Taco panel mounted on the wall. Check batteries in your thermostat if they have batteries0
Yea 2 zones.
did all that and it still keep doing same thing. Dose not want to connect just keeps clicking.0 -
You could try temporarily jumping the “end switch” terminals in the Taco panel. If that causes the boiler to operate, then the problem is with the Taco or a thermostat. If not, the problem is in the boiler.
Have you checked the condensate trap and drain for blockage?Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
