Non-Commercial Urinal Install
Hello my plumber friends and Happy Holidays! I have a raised-ranch house. My son lives downstairs where there is no bathroom. He often has his friends over to watch UFC and they all use my washroom sink if you know what I'm saying. I have what you may think is a bad idea to put an actual urinal in mounted to the wall of the closet under the stairs. I would remove the clothes pole and just use it the first 4 feet of closet (where it is tallest) for that purpose. The closet wraps around the corner under the landing to the down flight of stairs where the washroom wall is. The washroom sink drain ties into the washing machine drain and goes into this closet all on this wall. Then they connect to a main pipe under the stairs that leads underground to the septic. Any thoughts on this job? Besides the cost of the urinal, can it be done reasonably? Would it require a permit? Thanks! Jeff
been at it since the early 80s, commercial and resi plumbing, never heard of a urinal in a residential setting. Flushomter may need some good flow, but I haven't installed a urinal is over 30 years😃
In Massachusetts, yes you need a permit.1 -
Out here for urinals in small public restrooms that do not have a large water service to, you often see the spring loaded twist valve for flushing. Resembles the old school drinking fountains handle valves. Can cause some water hammer as it snaps shut.
I would recommend a urinal with the largest "target area" possible.
Some have side china "Modesty" wings as part of the castings, this helps with splash, overspray and late night accuracy.
Here, no permit needed. Actually if dark out they could go find some bushes.2 -
- 117 Geothermal
