ProPress Steel for Steam
Anyone have any thoughts or experience using Steel ProPress fittings on low pressure steam heating boilers? As a 4th generation steam boiler company, this goes against the grain. I would hate to get 2 or 3 hundred of these out and have them fail 5 years down the road.
    EBEBRATT-Ed Member Posts: 19,599
    Viega says propress & megapress are approved for low pressure steam. Who knows how long it will last?
    Derheatmeister
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    edited December 2021
    I’ve seen pictures of others using MegaPress on steam risers and headers, but I don’t think I would. Pipe threads and steam seem like a perfect match to me.
    Steve Minnich
  • delcrossv
    delcrossv Member Posts: 2,189
    Do they allow the joint to rotate as the pipe expands and contracts? Bet not.
    ethicalpaul Member Posts: 8,171
    I bet threaded mains don't allow any rotation either. Has anyone ever disassembled a threaded header and found that it turned without the help of a cheater pipe or torch?
  • delcrossv
    I do recall boiler leaks between sections due to welded headers. This seems similar. So something must be allowing some movement. You'd never notice a few hundredths of a degree in a header and the forces are enormous compared to a wrench.
  • Steve Minnich
    I’d take that bet and raise you.
    Steve Minnich
    delcrossv
    A lot depends on the distance involved
    Sure pipe out of one boiler tapping up and over and down to the second tapping. Keep the risers six inches long and you will have issue it can't move.
    Now picture the same thing with 10' risers. Will they flex now? You bet your butt they will.
    Even welded joints will flex if you give them enough room
    It's short distances that cause issues, if the pipe can move it will regardless of the material used.
    delcrossv
