ProPress Steel for Steam
SteamHeatTech
Member Posts: 2
Anyone have any thoughts or experience using Steel ProPress fittings on low pressure steam heating boilers? As a 4th generation steam boiler company, this goes against the grain. I would hate to get 2 or 3 hundred of these out and have them fail 5 years down the road.
I’ve seen pictures of others using MegaPress on steam risers and headers, but I don’t think I would. Pipe threads and steam seem like a perfect match to me.Steve Minnich0
Do they allow the joint to rotate as the pipe expands and contracts? Bet not.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
I bet threaded mains don't allow any rotation either. Has anyone ever disassembled a threaded header and found that it turned without the help of a cheater pipe or torch?
I do recall boiler leaks between sections due to welded headers. This seems similar. So something must be allowing some movement. You'd never notice a few hundredths of a degree in a header and the forces are enormous compared to a wrench.ethicalpaul said:I bet threaded mains don't allow any rotation either. Has anyone ever disassembled a threaded header and found that it turned without the help of a cheater pipe or torch?
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
ethicalpaul said:I bet threaded mains don't allow any rotation either. Has anyone ever disassembled a threaded header and found that it turned without the help of a cheater pipe or torch?Steve Minnich1
A lot depends on the distance involved
Sure pipe out of one boiler tapping up and over and down to the second tapping. Keep the risers six inches long and you will have issue it can't move.
Now picture the same thing with 10' risers. Will they flex now? You bet your butt they will.
Even welded joints will flex if you give them enough room
It's short distances that cause issues, if the pipe can move it will regardless of the material used.1
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 985 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
