Residential Boiler serviceability
Cleaning such a boiler is not a fun job. It appears that the 3 pass boilers allow cleaning to be done by swinging open the front door and not having to disassemble anything else (or maybe disconnect an oil line to burner). Am I missing something? It sure appears that it would be a lot easier than a design similar to what I have now.
You're correct. Triple pass boilers are generally better insulated for less idle loss and designed to cold start. An all around better choiceTo learn more about this professional, click here to visit their ad in Find A Contractor.0
This is my favorite boiler. Freeport 2
https://www.velocityboilerworks.com/product/freeport-2-fwz/
Sold a bunch of them and the model this replaced was called the Freeport. Rear flue was a problem sometimes when installed in a closet or alcove. when in a basement with the needed room for the rear flue to the base of the chimney, it was very efficient, and easy to service, brushing out the heat exchanger was super easy from the large front door.
Also liked Burnham, Buderus and other 3 pass boilers with large front door for cleaning.Edward Young Retired
Three-pass for me, always.
@EdTheHeaterMan , I've worked on one of the original Crown Freeports, here:
https://forum.heatinghelp.com/discussion/184249/you-can-tell-how-long-ago-this-was-serviced
Not a bad unit, if maintained properly. That one clearly was not.
The Freeport 2 you posted is similar to the Burnham MPO. There's also a steam version which is similar to the MegaSteam. ISTR they sell similar units under the New Yorker name. Ferguson sells the hot-water models under the Force name.
For reference, some other three-pass residential boilers are:
Axeman-Anderson NPO and Olympia (these are steel rather than cast-iron)
Biasi
Buderus G115 & G215
Dynatherm (yes, they're still around)
Slant/Fin Q3 (which appears to be Biasi-based)
Solaia (Biasi-based)
Trio (Biasi-based)
Utica Tri-Fire
Weil-Mclain Ultra OilAll Steamed Up, Inc.
Consulting1 -
Thanks Guys. 3 pass it is.0
Really can't go wrong with any of them, Buderus has strong distribution and support here so I lean towards them. Take a serious look at Energy Kinetics as well.To learn more about this professional, click here to visit their ad in Find A Contractor.2
Don't purchase anything if there is no local service support system. EK is great unless you can't find a trained service tech. Then everyone in your service area will just mess it up. See if you can get more than one contractor to offer the same product (or Brand Name). That will give you a clue if the product is supported in your area.Robert O'Brien said:Really can't go wrong with any of them, Buderus has strong distribution and support here so I lean towards them. Take a serious look at Energy Kinetics as well.
2 of the quotes are for the Buderus G115. Interestingly, these 2 have the greatest spread in price. The indirect are not the same but both are stainless tank/coil units and same size (~40 gal). Viessmann and Heat-Flo. Nothing against the techs here but my experience here in eastern, CT is that it's hard to find a good boiler tech. I finally decided to invest in my own emission test tools and wire brushes and have been doing it myself for years. As long as I can get parts, I'm not worried.0
Not just Eastern CT but Nation wide.MikeC555 said:2 of the quotes are for the Buderus G115. Interestingly, these 2 have the greatest spread in price. The indirect are not the same but both are stainless tank/coil units and same size (~40 gal). Viessmann and Heat-Flo. Nothing against the techs here but my experience here in eastern, CT is that it's hard to find a good boiler tech. I finally decided to invest in my own emission test tools and wire brushes and have been doing it myself for years. As long as I can get parts, I'm not worried.
You will still need a service company, WHEN you find one that's well trained with honest techs hold on to them. There few and far between unfortunately.1
- 111 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
