Web based modulating thermostat needed
I'm afraid this is something that only a BMS would be able to accomplish. Web based connectivity will require a static IP as well.0
Heh, nice necro.
@zepfan, are you sill looking for something to do this with? I've seen it done with a Honeywell T7350H1017 modulating (has relays too) communicating (LonWorks) thermostat & a Honeywell WebStat for remote access, but I had nothing to do with the remote access part so I can't tell you how much programming it needs or doesn't need. It is entirely self-contained & on site, no cloud servers needed.
A second way would be to add a modulating heating output to any old thermostat. I posted a config for a programmable controller here that will give you up to three stages of discharge-air-setpoint modulated output. You won't be able to see the actual analog command remotely without using Modbus, but you'll be able to figure out the target temp by the number of heating stages calling.
- 50 Industry Classes
