Burnham X2 or Crown Aruba?
About to order the new boiler for my home. Either one better than the other? Anyone have experience with either?
Thanks!
  • Ironman
    Ironman Member Posts: 7,859
    Burnham and Crown are the same. Both are part of US Boiler.
    Bob Boan
    oldradiator
  • Ironman
    Who’s gonna install the boiler? IDK of any reputable contractor that wants to install a boiler that a HO purchased himself.
    Bob Boan
  • oldradiator
    oldradiator Member Posts: 40
    I’m not buying it myself - he is.
  • Ironman
    If you’re going with an atmospheric boiler, you need to expect that if you have a masonry chimney that it needs to be relined with a stainless steel liner. You cannot vent a newer, higher efficiency appliance into a masonry chimney because its flue gas temperatures are much lower.
    Bob Boan
