ways -options to heat multiple igloo's outdoor
creger.robert
Member Posts: 108
in Gas Heating
looking for suggestions on heating igloo's multiple-for outdoor dining-other the straight electric
Can you use LP fired radiant heaters? Here's one: https://www.amazon.com/Dyna-Glo-DGPH201BR-Premium-Hammered-Bronze/dp/B01DKNP5E4/ref=sr_1_6?crid=3SPNTBC5RPQ9W&keywords=dyna-glo+delux+125,000+btu+propane+lp+radiant+portable+heater&qid=1638394601&sprefix=lp+radiant+p,aps,220&sr=8-6 but as you will see when you go there there are many other designs and sizes and prices...Br. Jamie, osb
fire marshall wont allow propane heaters in igloo here
Good for them!creger.robert said:fire marshall wont allow propane heaters in igloo here0 -
Oh great. Well, he or she might have a point. However, let us consider your predicament, then. You want to heat up an outdoor igloo. That means you need a heat source, and preferably a radiant one so you are heating your patrons, not the great out of doors. That means you either have fire (or catalytic heat from fuel) or electricity. Your fire marshal will not allow fire or catalytic heat.creger.robert said:fire marshall wont allow propane heaters in igloo here
Or will he or she allow fire? Would he or she permit a small fire pit in each igloo? Might be worth an enquiry, as logic is not necessarily a strong point...something like this: https://www.amazon.com/BALI-OUTDOORS-Propane-Rectangular-Tabletop/dp/B07JFSKSSF/ref=asc_df_B07JFSKSSF?tag=bingshoppinga-20&linkCode=df0&hvadid=80058245652742&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583657822603837&psc=1?
Otherwise... looks like electric radiant is what you're stuck with.Br. Jamie, osb
- 15.8K Strictly Steam
