Radiant Heating Pipe Size Assistance
Cverhag
Member Posts: 1
Good evening,
I'm remodeling a home in central WI and have a boiler system with aluminum fin tube baseboards on copper pipe. Ranch style, two zones; main floor & basement. Since I've taken all the walls down to studs and put drywall up, I'm having to move all the registers to get them in the right position. I've also decided I'm going to replace the current copper pipe with Pex-A tubing (I'm passable on sweating copper, better with PEX). I measured the current pipe at nearly 15/16" OD and over 3/4" ID and was planning on putting 3/4" PEX. I guess I just need some reassurance that I'm replacing the old stuff with the right size pex. I'm sure there is flow rates and heat loss calculations but i'm just following the current path to replace and only moving a few registers so I figure I just need to replace with the right size to maintain integrity of the originally designed system.
Thanks!
Thanks!
3/4 PEX should work fineBr. Jamie, osb
I agree, 3/4" will work fine unless your lengths are really long.
Be sure to use a pex tubing with an O2 barrier. Uphoner Hepex is popular pex-a with barrier."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
@Cverhag
FWIW The tubing you measured is actually 7/8" od which is 3/4 nominal copper tubing. In AC & Refrigeration the same size is called 7/8 OD copper tubing.
Welcome to the world of the American misfit measuring system. All kinds of confusion0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
