Hydrolevel VXT question
delcrossv
Member Posts: 2,203
On a VXT, if I set it for 1 gallon, does that mean it fills until the LWCO is covered and then adds an additional gallon?
It depends on how far below the water line the LWCO probe is. Some (mostly older) boilers didn't put the primary probe tapping in the most appropriate place.EBEBRATT-Ed said:How much you set it for depends on the physical size of the boiler,
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
