Hydrolevel VXT question
delcrossv
delcrossv Member Posts: 2,204
On a VXT, if I set it for 1 gallon, does that mean it fills until the LWCO is covered and then adds an additional gallon?
    Jamie Hall Member Posts: 27,767
    I believe it adds 1 gallon -- more or less.
    Gordodelcrossv
    EBEBRATT-Ed Member Posts: 20,969
    You can set it for 1,2,3,4 or 5 gallons. When the water comes up to the probe level and your set for 1 gallon it adds 1 gallon above the probe set for 2 it adds 2 gallons etc.
    How much you set it for depends on the physical size of the boiler,
    delcrossv
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,929
    It depends on how far below the water line the LWCO probe is. Some (mostly older) boilers didn't put the primary probe tapping in the most appropriate place.
