Dunkirk
PDC1
Member Posts: 1
in Oil Heating
So I have a Dunkirk Gas hot Water Boiler with a honeywell s9361a2070 Control
I am showing Sta 1 with no error codes, the Draft motor does not start but I know it is good, I put voltage to it and it went on
Please Help Rob
Please Help Rob
need pictures and a wiring diagram if you can post it0
Sta= Stable, which means it's just waiting.
Check the thermostat and where the thermostat connects on the Honeywell control.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
