Runtal Radiators
Member Posts: 4,510
It was my first time using FostaPEX; that was kind of fun.
Roughing in the stub outs had to be on the money with the connections at opposite ends. I don't recommend doing it without the radiators and valves there to confirm the measurements. And then they changed the baseboard height and the stub outs had to be done all over again.
It's getting up and down off the floor that's hard. Over and over again wears me out. Perhaps I'll feel better about it in the morning.
Now that it's all done and the owners are happy is a big plus.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
They are heavy and awkward. i think there are accessories that would help with your rough in so it didn't have to be dead on, it could be covered.0
I feel your pain. Runtals take much more time and effort than a #22 wall panel radiator. Some clients prefer their look and are willing to pay the difference. I use a rigid hanger to keep the stub outs secure, and that has avoided SR damage to rough-in. I also prefer the Oventrop TRV's, which are more compact.0
I also prefer the Oventrop TRV's, which are more compact.I like them as well, but for some reason, they've been difficult to find.
Ahh the UF Series Rads...Bomb proof Rads.
Yes these Rads can wear you down!
In Germany we had to pipe these using black Steel pipe that had to be filled with sand first then heated to be Cherry red with the Oxy torch and bend
The walls were also solid Concrete so the Hilti hammer drill was our best friend.
Also teflon was not used back then so hemp was the way we made our connections.
Great job..2 -
Runtal rough in is a pain. We usually block them out a 1/2 + so the male adapters can actually protrude out the rock and we actually can back them up. Not my fave.0
Oh. I've seen the bent pipe in Germany. I assumed it was thinner wall and bent with tools similar to electrical conduit.Derheatmeister said:Ahh the UF Series Rads...Bomb proof Rads.
Great job..0 -
"mattmia2 ....Oh. I've seen the bent pipe in Germany. I assumed it was thinner wall and bent with tools similar to electrical conduit."
We used regular Black steel pipe such as you would use for gas piping..
We filled it with sand so that it would not collaps, then we marked the location of the bend with soap stone,heated the marked area until it was cherry red and bend the pipe..
Tees/Branch off where also hand made.
Over here they call this Pipe fitter.
The company i worked for (Haushalter) had approx 90 employees and did residental/and Large commercial jobs in and around Bad Homburg vdh /Frankfurt area.
In the 1980 ties we Started pressing black pipe using the Mannesman press system which cut the labor in half.
@Derheatmeister I'm impressed. That work sounds impossible, but if you do it long enough, I suppose you learn all the tricks. Sehr schön gemacht!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Why do we use thick wall steel for low pressure? Soft copper sounds easier. Or at least thin wall tubing.@Derheatmeister I'm impressed. That work sounds impossible, but if you do it long enough, I suppose you learn all the tricks. Sehr schön gemacht!
"So arbeiten wir aber heute nicht mehr"..I do not work like that nowadays anymore..@Derheatmeister I'm impressed. That work sounds impossible, but if you do it long enough, I suppose you learn all the tricks. Sehr schön gemacht!
My Chiropractor tells me not to obuse myself and i am currently spending some serious time on a machine that decompresses my lower back..
I am also switching gears to my profession which is importing European heating components such as Sacrificial Anodes,Deionizers, Dissolved Oxygen sensors and Scale Transformers.
Das ist wunderbar..0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
