Passaic County Church needs help with steam / buried piping too - Who is good and in the area?
Church has leaking buried pipe. Bangs and sloshing sounds in pipe.
    Jamie Hall Member Posts: 27,206
    @clammy , @EzzyT ... for starters. However, that is a sufficiently vague description that it might be helpful to them -- and the rest of us -- to have more detail...
    The leaking buried pipe will, of course, have to be replaced.
    Ironman
  • Boiler Talk
    Boiler Talk Member Posts: 147
    Knowing that someone like you can immediately answer provides assurance. I don't have pictures, but I think it is a combination of boilers if that is possible. The pastor talked about 6 boilers. I saw them once and I think the near piping was not right. But I also saw a repair that linked larger to smaller to larger again piping that undoubtedly leads to banging. I don't have any more information. Faith and works. I will provide the links to Clammy and EzzyT and listed the Resource Center NJ.
  • EzzyT
    EzzyT Member Posts: 1,379
    @Boiler Talk the best way to reach me is at 2018878856
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
