Baseboard steam radiator
davey73
Member Posts: 10
Do they make baseboard radiators for gravity steam? 1 inlet?
You can run cast iron baseboard on steam, BUT running it as 1 pipe is fraught with issues due to the relatively small passages and pipe size. In addition you have to slope it appropriately across the wall for the gravity drain which, depending on length, can look weird.davey73 said:Do they make baseboard radiators for gravity steam? 1 inlet?
Typically if it's done and works, it's done as 2 pipe.
We've had plenty of people come on this forum having issues with them, personally I wouldn't ever do it.0 -
You need to better explain your need and the type of system you are inquiring about. You can buy cast iron baseboard for 2 pipe steam or Finned tube radiation for both 1 and 2 pipe steam systems. If you are asking about cast iron baseboard for a 1 pipe steam system, it is not recommended but I have seen it done with very poor performance and a lot of noise.0
CI baseboard will work on steam but only if hooked up two pipe IMHO0
- 15.8K Strictly Steam
