Ugg to Snugg wall hanger job
GW
Member Posts: 5,137
Just like a hair cut in the Marines
wish I had time and energy to fix the hole in the window—-the plumber did the water heater years ago and left the original power venter wall thimble
low voltage kicked my knees, 62 points of contact (5 zones), relocate thermostat wiring, etc
yes we normally paint
2
Thanks! yes we had paint with is, but painting around the existing water heater wasn't gonna happen0
And the vent decals are required in Mass. Some nut job apparently tied some plumbing into a furnace/boiler vent. Can we please get a new set of law makers, PLEASE?1
ThanksWe normally use this little neutralizer bullet. But this one we drained into the existing condensate pump (higher up the wall)so we did the old fashion dandy set up with marble stones0
Am I the only one who would actually like to watch the end result of this? It'd be great with a taller building. Maybe pointed to an adjacent building or a driveway with parked cars?GW said:And the vent decals are required in Mass. Some nut job apparently tied some plumbing into a furnace/boiler vent. Can we please get a new set of law makers, PLEASE?
I'd die right there on the floor. From laughter.0 -
Ahh the “plumber” guy tying into the furnace venting? I would think the drainage would run back to the furnace
the world is filled with lawmakers (code writers) that try to keep idiots from harming themselves and innocent bystanders0 -
Isn't the venting and heat exchanger all sealed? I would think it would fill up eventually and what's coming down after that is going to want to go somewhere.GW said:Ahh the “plumber” guy tying into the furnace venting? I would think the drainage would run back to the furnace
