Ugg to Snugg wall hanger job
GW
GW Member Posts: 5,137
Just like a hair cut in the Marines
wish I had time and energy to fix the hole in the window—-the plumber did the water heater years ago and left the original power venter wall thimble
low voltage kicked my knees, 62 points of contact (5 zones), relocate thermostat wiring, etc
yes we normally paint
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
PC7060Solid_Fuel_Man
  • PC7060
    PC7060 Member Posts: 1,757
    edited October 2021
    Nice work! Love the intake and exhaust labeling.
    Always like the painted panels myself but very tough to do on a short schedule.
    GW
  • GW
    Thanks! yes we had paint with is, but painting around the existing water heater wasn't gonna happen
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    And the vent decals are required in Mass. Some nut job apparently tied some plumbing into a furnace/boiler vent. Can we please get a new set of law makers, PLEASE?
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    PC7060
    EBEBRATT-Ed Member Posts: 19,605
    @GW
    Don't know if we are worse than California, but it's close
  • GW
    Ed you got me there!
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • Ironman
    Ironman Member Posts: 7,869
    edited October 2021
    Nice nice job, Gary.
    I like the homemade neutralizer. I’ve made them using a water filter housing.
    Bob Boan
    GWmattmia2
  • GW
    ThanksWe normally use this little neutralizer bullet. But this one we drained into the existing condensate pump (higher up the wall)so we did the old fashion dandy set up with marble stones
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • JakeCK
    JakeCK Member Posts: 1,502
    Am I the only one who would actually like to watch the end result of this? It'd be great with a taller building. Maybe pointed to an adjacent building or a driveway with parked cars?
    I'd die right there on the floor. From laughter.
  • GW
    Ahh the “plumber” guy tying into the furnace venting? I would think the drainage would run back to the furnace
    the world is filled with lawmakers (code writers) that try to keep idiots from harming themselves and innocent bystanders
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    mattmia2 Member Posts: 15,637
    If you've ever seen anything that a cable "installer" has done in the past 20 years or so you'd understand why this is necessary.
    Solid_Fuel_Man
  • JakeCK
    Isn't the venting and heat exchanger all sealed? I would think it would fill up eventually and what's coming down after that is going to want to go somewhere. :p
    GW
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Nice work!
    Personally I'd think trying a plumbing vent into combustion air would give a very nice boost in system efficiency  >:) only gas needed would be the initial firing....then no more gas....or building....
    GW
