Need a new boiler
davey73
Member Posts: 9
My old Burnham steam boiler is leaking water. It’s an old beast and needs to be replaced. I have recently had gas installed from the street and want to change over to gas from oil. I’m told that my chimney needs to be lined to accept a gas fired boiler. I’m told it’s very expensive to do. I was also told that they have direct vent steam boilers but I can’t find any. Do they exist?
You need to call for an inspection and the price for a SS liner.
It may not be as much as you are expecting.
Side venting involves a power vent and extra controls....more money and also noise.
Do you know what size of boiler you need?
It is not good to go for the same size you have now. Most boilers are oversized already.
Your contractor should do a radiator survey to decide the sizing.
If he just looks at the old nametag and wants to go with that, then you know he may be a hack.
Could you post pictures of your existing boiler piping....floor to ceiling....several sides. Sometimes there can be some improvement in piping to lower fuel consumption.2 -
Unless you have a problem chimney, or it's deteriorating, a SS line and power venting may be the same price.
Assuming an old home and stone or large masonry foundation, unless they are utilizing a window for a power venter, might be a lot of work to bore thru.
If you can do the liner, that's the best way to go.
Glad you got your gas line in. Gas prices going up, in some places 30%, and usually stays up.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
