Honeywell thermostatic mixing valves/heat only
1idmfd
Member Posts: 2
New mixing valve not working (radiant,) other three work fine
That's just a bit vague... can you be more specific?Br. Jamie, osb
Is the mixing valve new because the old one wasn't working, and now the new one isn't working?
Are all 3 new?
High temp, low temp, no temp?
Circulator is running?
All circuits are purged, well?
Toilet flushes?
need to develop my x ray vision0
Okay0
It might be broken.
Of course it can be bad out of the box, but not likely. I had a bad out of the box thermocouple the other day.1idmfd said:System is brand new.4zone radiant on a Navien.. 110 heat only boiler. My question is can the mixing valve be defective out of the box? How can I determine and/or test?
Have you tried swapping mixing valves with one you know works?
What make and model valve?
What make and model radiant block?
How many loops?
What size?
How long is each loop?
What make and model circulator?
What's happening (or not happening) that makes the mixing valve bad?0 -
and , of course, pictures,
general wide angle view of the bad valve as it's piped and installed,
and of one of a working valve,
known to beat dead horses0
