Honeywell thermostatic mixing valves/heat only
1idmfd
1idmfd Member Posts: 2
New mixing valve not working (radiant,) other three work fine
    Jamie Hall Member Posts: 26,559
    That's just a bit vague... can you be more specific?
    HVACNUT Member Posts: 7,094
    Is the mixing valve new because the old one wasn't working, and now the new one isn't working?
    Are all 3 new?
    High temp, low temp, no temp?
    Circulator is running?
    All circuits are purged, well?
    Toilet flushes?
    EBEBRATT-Ed Member Posts: 18,893
    need to develop my x ray vision
  • GroundUp
    GroundUp Member Posts: 2,431
    Okay
  • STEVEusaPA
    It might be broken.
  • 1idmfd
    System is brand new.4zone radiant on a Navien.. 110 heat only boiler. My question is can the mixing valve be defective out of the box? How can I determine and/or test?
    mjstraw
    Of course it can be bad out of the box, but not likely. I had a bad out of the box thermocouple the other day.
    Have you tried swapping mixing valves with one you know works?
    What make and model valve?
    What make and model radiant block?
    How many loops?
    What size?
    How long is each loop?
    What make and model circulator?
    What's happening (or not happening) that makes the mixing valve bad?
  • neilc
    neilc Member Posts: 3,062
    and , of course, pictures,
    general wide angle view of the bad valve as it's piped and installed,
    and of one of a working valve,
    known to beat dead horses
