Steam Change-Out
Dan Foley
Member Posts: 1,268
Slavko, Dragon, JJ and crew replaced the steam boiler in a 1920’s 16-unit apartment building in DC. The Peerless 211 replaced a 30 year old W-M LGB tied to a one-pipe system. A tekmar 279 operates the boiler.
The client was a joy to work with and got along great with my crew. It took four days but would have finished easily a day earlier if we could source the fittings in a timely fashion. Materials are harder than ever to track down.
9
Nice. Looks like a lot of pipe for a small boiler!!!0
That was my thought too when I just looked at the picture, Ed. But then I saw its a Peerless 211... the smallest model ( which it looks like this is) is 630,00 input. Needs big piping, though probably not 2x4 inch risers (Is that what there are?) , but a drop header was probably the only way to get proper height risers out of the boiler. I see boiler after boiler installed with risers that are too short, and I heard the excuse" there's not enough room to get taller risers" out of mouths of Chicago Steam boiler "experts" that have been installing like this for decades ( along with things like all welded near boiler piping).To learn more about this professional, click here to visit their ad in Find A Contractor.0
Not a big fan of drop headers but this is a perfect example of a job that really needs one. Time and a place for everything0
That should save your client some money and with natural gas prices going up he should be a happy guy.Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge0 -
Outstanding and perfectly thought out installation.
I do not often care for drop head installations but in this case i kinda agree with the installing contractor.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Just pulled up the specs on that tekmar. Sweet!
How much of an efficiency boost does that provide over a regular non-programmable stat?Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
- 117 Geothermal
