Cast Iron BB Remodel
EvenCmft
Member Posts: 5
I have a customer looking to take out their cast iron baseboard to have stripped and repainted. I told them I am not comfortable removing this due to its length and the angle that it has. It is about 20' with a 45-degree bend about a third of the way from one of the ends. My discomfort comes from thinking that I may torque the connecter nipples that may cause a leak. Has anyone removed CIBB and kept it one piece to have cleaned and repainted? All help is greatly appreciated.
Thanks
Brian Evenson
Even Comfort
West Michigan
Thanks
Brian Evenson
Even Comfort
West Michigan
EBEBREATT-Ed That is what I was thinking of, but looking for someone to help confirm or deny my thoughts. Thanks0
Stripping it chemically and repainting it in place would make a lot more sense, and almost certainly cost less.—
Bburd0 -
We removed all our CIBB, laid it on the floor (blocked), stripped + primed (on site), put it back up. There are a couple 20 footers. IIRC it was pressure tested and filled with water for leak tests. So far so good. New boiler etc will be fully commissioned in the coming weeks. Full re-pipe with O2 barrier PEX.
IIRC plumber was not confident to move it off site for re-finishing.
I second what Ed said. Get some new push nipples and the draw tool.
https://www.consumersplumbing.com/heating-burnham-baseboard/
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
