boiler water feeder replacement
courtgood
courtgood Member Posts: 2
I HAVE A STEAM BOILER AND THE CONTRACTOR REPLACED MY VXT programmable water feeder model vxt-24 with a Mcdonnell & Miller universal water feeder model number wfe-24 should I be alarmed
    Jamie Hall Member Posts: 27,248
    No. Not if he did it right, anyway. Both are perfectly good.
  • courtgood
    thank You :)
    EBEBRATT-Ed Member Posts: 20,085
    Most like the VXT better
  • KC_Jones
    KC_Jones Member Posts: 5,930
    The downside is you now can't monitor how much make up water the boiler is using. I am of the opinion this is a fairly critical point as excessive make up water is what can destroy boilers.
    2014 Weil Mclain EG-40
