boiler water feeder replacement
courtgood
Member Posts: 2
in Gas Heating
I HAVE A STEAM BOILER AND THE CONTRACTOR REPLACED MY VXT programmable water feeder model vxt-24 with a Mcdonnell & Miller universal water feeder model number wfe-24 should I be alarmed
No. Not if he did it right, anyway. Both are perfectly good.Br. Jamie, osb
thank You
Most like the VXT better0
The downside is you now can't monitor how much make up water the boiler is using. I am of the opinion this is a fairly critical point as excessive make up water is what can destroy boilers.0
