Dead Men Tales: Plastics!
Plastics!
There’s a scene in The Graduate where Mr. McGuire says to Benjamin, “I want to say one word to you...Plastics!...There’s a great future in plastics.” This was around the time that Thomas Engel invented PEX. In this episode, Dan Holohan shares how plastics entered the HVAC industry and how not everyone was as enthusiastic about it as Mr. McGuire.
Listen and subscribe story here.
Thank you to our sponsor SupplyHouse.com.Comments
In the late 70's my wholesale supplier's rep would stop occasionally.
Herbie had been the the business many years.
He told me of the introduction of PVC to the industry in the 60's.
Of course plumbers/pipefitters were not taking to some piping that just anyone could glue together. Cast iron and copper were the only products in use for DWV and it took skill to install.
The company (that beige colored PVC) factory rep was telling Herbie that the trades had not to worry, because this new revolutionary product would never be sold in the retail market.....only thru wholesale houses....so there!
Dan, your story has much more truth than mine.0 -
I remember when my grandfather commented on ABS and PVC pipe and fittings were introduced to the wholesale market..."now anyone with a hacksaw and a can of glue will be doing plumbing". He was sorta correct.0
Chicago required threaded iron pipe and lead services from the street into the 80s. Only when Congress banned lead pipes in 1986, did the city have to change the code. Sewer lines are still clay tile or cast iron . . . no plastic . . . . the trees are flourishing. When my friends move into a new condo or house, they almost always insist on new bathrooms and kitchens . . . there is still plenty of work for plumbers!0
In a world where things should be built like granite we come to the thing called plastic.
There are many kinds of plastics some of them are hard like granite and some are as soft as a babies behind. But plastic is used on so many things each with it's own formula suited for the need.
But I remember when plastic was bakalite and used on telephones and other items that needed to be made cheaply and have a relatively long life.
Plastic to me many instances means some things are fluid like a politician that changes their mind many times for self betterment.
So much for plastic in humans but remember many plastics are good and some are used in high temperature furnaces to produce energy, not like a politician.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
ABS and polycarbonate plastics, used on modern cellphones are several times tougher than bakalite.dopey27177 said:
But I remember when plastic was bakalite and used on telephones and other items that needed to be made cheaply and have a relatively long life.0 -
Bakelite is very durable in a lot of ways like chemical and temperature and abrasion but it is brittle, so it has to be applied properly like any other material. Being a thermoset it can be more difficult to mold.0
A story from a long gone WW2 vet. He had returned and was working in the electrical field. He had gotten a new screwdriver that did not have the standard wooden handle. It was the new plastic something.
He was showing it off to another worker who thought it was glass and not worth a damn. The other worker took it and slammed it down on concrete, certain it would shatter. Instead it bounced back up and almost took his eye out.
New technology can be dangerous. FWIW0 -
Anyone familiar with "transite"? Asbestos cement for water supply in 70s? Is it considered bad?jep said:Chicago required threaded iron pipe and lead services from the street into the 80s. Only when Congress banned lead pipes in 1986, did the city have to change the code. Sewer lines are still clay tile or cast iron . . . no plastic . . . . the trees are flourishing. When my friends move into a new condo or house, they almost always insist on new bathrooms and kitchens . . . there is still plenty of work for plumbers!
