Troubleshooting the Cuckoo’s Nest
HeatingHelp
HeatingHelp Administrator Posts: 722
edited September 2021 in THE MAIN WALL
imageTroubleshooting the Cuckoo’s Nest
If you can work a steam-heating system back into the shape it was in when new (that being fast, quiet and efficient), your customers will never go anywhere else. And they will tell everyone they know that you are the best around.
Read the full story here
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,708
    Thanks, @larrybard! I appreciate you.
    Retired and loving it.
  • briski58
    briski58 Member Posts: 8
    Yeah Dan likewise!!! Every time I login I learn more and more about steam heating!! Thank You!
  • DanHolohan
    Great to know that! Thanks, @briski58
  • jep
    jep Member Posts: 16
    I always love reading these entries. I learn so much . . . engineering at the turn of the century was already so developed . . . but I guess even the Romans had steam baths.
    Steamhead Member Posts: 18,468
    So, did they ever get that building straightened out?
    Consulting
  • DanHolohan
    I don’t know, Steamhead. I like to think in optimistic terms. The boiler is half full!
    ratio
    mattmia2 Member Posts: 16,683
    Because the other half is being thrown up in to the mains faster than it can return...
    PC7060
  • CurtisD
    CurtisD Member Posts: 1
    I've personally learned alot from Dan Holohan over the years and moving recently from the northeast to NC,SC area have found this exact issue all over with steam heat being ran at 8 psi & up without even the technicians understanding the issues. I try to teach what ive learned and the use of a left handed screw driver.
  • DanHolohan
    Thanks for trying!
  • bporter1
    bporter1 Member Posts: 3
    I worked in Greensboro NC, and I was surprised to find a lot of one pipe steam in the older homes. Some homeowners ripped out the piping and the radiators, but most kept them. The guys I worked with at the time had no clue what steam heat was- let alone a boiler.
  • Anthony Menafro
    Anthony Menafro Member Posts: 200
    I absolutely love the challenges that steam heat brings!
