Need Maintenance near Steamboat Springs, CO
Stout
Member Posts: 2
I’m looking for someone to do an annual maintenance / troubleshoot intermittent ignition problem on a Weil-McLain Ultra 105 boiler near Steamboat Springs, CO. It seems like most of the posters are east coast based, but thought I’d give it a try; thanks in advance.
Hi, I did and there was nobody within 100 miles. Maybe going to some local supply houses could be a way of getting some decent leads.
Yours, Larry0 -
Seems to me that there is someone somewhere in Colorado who comes on here now and then. Perhaps he'll see this...
What sort of maintenance?Br. Jamie, osb
I'm in Colorado, but Steamboat is nearly a six hour drive for me, sorry. Agree with @Larry Weingarten, try calling the supply houses and see who they would recommend.0
Isn't @Mark Eatherton also in CO?0
@Simply Rad is in Steamboat. You might drop him a PM"If you can't explain it simply, you don't understand it well enough"
Albert Einstein2 -
Der Heatmeister?0
He is 2 hours away.nicholas bonham-carter said:Der Heatmeister?
Albert Einstein0 -
Yes we are in Summit Country which is a couple hours away..We Service Alma,Blue river,Breckenridge,Frisco/Copper Mtn, Silverthorne/Wildernest,Dillon/Keystone/Montezuma and a couple Systems in Leadville/Camp Hale..We also have not taken on any new customers for about 2 years but will make acceptions with Viessmann boilers due to the Lack of Qualified technicians that are able to service them..
Are there any stickers on the boiler from the original installer ?
As mentioned above Jeffrey with Simply Radiant which likes Viessmann Boilers is in Steamboat and MAY be able to help but certainly does not stock any parts for these boilers..If Jeff can not help you should reach out to the local Weil McLain Rep/Denver for advise on which Service company is within your area.
Hope this helps.
Richard/ Heatmeister Group.
How far is Craig, CO?
- 120 Geothermal
