Need Maintenance near Steamboat Springs, CO
Stout
Stout Member Posts: 2
edited August 2021 in THE MAIN WALL
I’m looking for someone to do an annual maintenance / troubleshoot intermittent ignition problem on a Weil-McLain Ultra 105 boiler near Steamboat Springs, CO. It seems like most of the posters are east coast based, but thought I’d give it a try; thanks in advance.
    EBEBRATT-Ed Member Posts: 19,390
    @Stout
    Check "find a contractor on this site"
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,990
    Hi, I did and there was nobody within 100 miles. Maybe going to some local supply houses could be a way of getting some decent leads.
    Yours, Larry
    Jamie Hall Member Posts: 26,754
    Seems to me that there is someone somewhere in Colorado who comes on here now and then. Perhaps he'll see this...
    What sort of maintenance?
  • delta T
    delta T Member Posts: 884
    I'm in Colorado, but Steamboat is nearly a six hour drive for me, sorry. Agree with @Larry Weingarten, try calling the supply houses and see who they would recommend.
    mattmia2 Member Posts: 15,345
    Isn't @Mark Eatherton also in CO?
  • Zman
    Zman Member Posts: 7,611
    @Simply Rad is in Steamboat. You might drop him a PM
    Albert Einstein
    mattmia2Derheatmeister
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    Der Heatmeister?
  • Zman
    Der Heatmeister?
    He is 2 hours away.
    Albert Einstein
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Yes we are in Summit Country which is a couple hours away..We Service Alma,Blue river,Breckenridge,Frisco/Copper Mtn, Silverthorne/Wildernest,Dillon/Keystone/Montezuma and a couple Systems in Leadville/Camp Hale..We also have not taken on any new customers for about 2 years but will make acceptions with Viessmann boilers due to the Lack of Qualified technicians that are able to service them..
    Are there any stickers on the boiler from the original installer ?
    As mentioned above Jeffrey with Simply Radiant which likes Viessmann Boilers is in Steamboat and MAY be able to help but certainly does not stock any parts for these boilers..If Jeff can not help you should reach out to the local Weil McLain Rep/Denver for advise on which Service company is within your area.
    Hope this helps.
    Richard/ Heatmeister Group.
  • captainco
    captainco Member Posts: 832
    How far is Craig, CO?
  • Zman
    About 45 minutes from Steamboat. Who is there?
    Albert Einstein
