Combustion analysis
rgar98
Member Posts: 66
I cannot find an independent oil technician in Montgomery County Maryland (Silver Spring) to do an analysis of my oil burner set-up. The "Find a Contractor" link is not helpful.
What about the company from where you buy your oil?
@Steamhead Is this in your area?
We don't usually go down that far..... @rgar98 , how about @Dan Foley ? If his company, Foley Mechanical, doesn't do this he probably knows someone............ChrisJ said:@Steamhead Is this in your area?
Consulting1 -
I cover VA, MD, and DC from Richmond up to Hagerstown / Baltimore. And a little bit of PA.
But I do commercial and industrial boilers. I have a ton of customers in Silver Spring.
+1 for Dan Foley. If Dan can’t do it for some reason let me know and I will help you out.Never stop learning.0 -
Thanks Mike, I appreciate that.0
There is a company in Silver Springs called D&D Services. Not sure if they do oil but they have been certified by NCI on Combustion testing. Foley are good guys too,0
